Flexlib for SSDR 1.43 Question
Paul Burton
In Flexlib for SSDR 1.36 there was a slice event called slice.ProperetyChanged which fired every time the frequency changed for that slice, allowing the continuous monitoring of frequency. In Flexlib for SSDR 1.43 that event is gone and I am not unsure of how to continuously monitor frequency. Can anyone help?
I am using FlexLib 1.43 and the event you reference still exists.
slc.PropertyChanged += slc_PropertyChanged;
Make sure you have correctly typed the event name.
Thanks for the reply Mark. However, I cannot find any PropertyChanged events in FlexLib 1.43 nor any event with a name starting slc. What class is this event under? Maybe I'm just overlooking it.0
The namespace is Flex.Smoothlake.FlexLib
The Slice object has a PropertyChanged event.
In my earlier code snip-it slc was my local variable name for the Slice object.
What development environment are you using?
What is your .NET developer experience level?
OK, Mark, I now see my problem and it now works fine. Thanks for the help. My experience with .Net development is low (as you can probably tell) but I'm trying.
- 378 Community Topics
- 118 SmartSDR+
- 193 DAX
- 38 Aurora
- 257 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
