Flexlib for SSDR 1.43 Question
Paul Burton
Paul Burton Member ✭✭
edited February 2018 in SmartSDR for Windows
In Flexlib for SSDR 1.36 there was a slice event called slice.ProperetyChanged which fired every time the frequency changed for that slice, allowing the continuous monitoring of frequency.   In Flexlib for SSDR 1.43 that event is gone and I am not unsure of how to continuously monitor frequency.  Can anyone help?
  • Mark_W3II
    Mark_W3II Member ✭✭✭
    I am using FlexLib 1.43 and the event you reference still exists.
    slc.PropertyChanged += slc_PropertyChanged;
    Make sure you have correctly typed the event name.
  • Paul Burton
    edited May 2015
    Thanks for the reply Mark.  However, I cannot find any PropertyChanged events in FlexLib 1.43 nor any event with a name starting slc.  What class is this event under?  Maybe I'm just overlooking it.
  • Mark_W3II
    edited April 2015
    The namespace is Flex.Smoothlake.FlexLib
    The Slice object has a PropertyChanged event.
    In my earlier code snip-it slc was my local variable name for the Slice object.
    What development environment are you using?
    What is your .NET developer experience level?
  • Paul Burton
    edited May 2015
    OK, Mark, I now see my problem and it now works fine.  Thanks for the help.  My experience with .Net development is low (as you can probably tell) but I'm trying.
