Welcome to the FlexRadio Community!  Please review the new Community Rules and other important new Community information on the Message Board.
Flex3000 not responding to "dits" when using internal keyer and a paddle
                    M Hayden
                    My F3K does not respond to paddle "dits" at all.  It isn't the paddle, I have tried two and the paddles work on other rigs.  The paddles are wired properly.  Using the "reverse" option in the keyer setup moves the problem to no dashes.  The "iambic" option works as expected, toggling between keyer and straight key.  I'm running PowerSDR 2.7.2 on a fast PC (no latency issues at all, and CPU runs only 4%).  Radio works FB otherwise.  The radio is well out of warranty.  Any ideas before I "go in"?
Tnx
Mike AK3F
                Tnx
Mike AK3F
            Does it perform OK when using CWX ?0
            Mike, I tried it on my Flex3000 and my paddle works. I would suggest to have a look at the
 F3K socket a measure connections to the PCB for a fault, if you are sure it's not a software problem.
 73, Alex DH2ID0
            Andrew, yes, CWX works fine so the keying software is working ok.. Alex, thanks for checking yours. I suspect a solder fault too, and that's where I will start. Or maybe the quad gate fed by the "Key" jack. It won't be difficult to check.
 Very odd it would just start though, but odder things have happened.
 I'll report how I resolve it.
 Mike, AK3F
            I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
            I would have asked the same question as Andrew about CWX. I was clipping off about half of the first dit sent while using the CWX panel. I set the repeat delay to 10 and everything was fine. This only affected things while using CWX. Good luck0
- 355 Community Topics
- 619 The Flea Market
- 8K Software
- 17 SmartSDR+
- 6.3K SmartSDR for Windows
- 414 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 221 FLEX-8000 Signature Series
- 927 Maestro
- 900 Genius Products
- 458 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 117 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 980 Third-Party Software
