Has anyone managed to run fldigi via remote with 1.4.3? I am decoding ok, but skeptical about TX!
Bill,
To my way of thinking, DAX was made for running fldigi remote.. The Remote function just allows you to hear the audio on the remote speakers but is NOT required for decode/encode if you have DAX configured.
AL, K0VM
I ran FLDigi remotely using SmartSDR v1.3.8 without the remote features added in v1.4.x.
DAX is intended for digital mode operations and bypasses much of the audio processing (such as the equalizer) that is used for voice operations. The remote feature in SmartSDR v1.4.x allows you to send audio to/from the radio without using DAX and therefore have all of the audio processing available for voice operations. A digital mode such as FLDigi uses DAX to transfer audio to/from the radio and does not need the remotes features added in SmartSDR v1.4.x.
Since no hardware connections are required for connecting a digital mode program to SmartSDR, it makes no difference whether the computer used is a desktop sitting next to the radio in your shack or a laptop operated from the comfort your recliner in the living room.
73, Ray, K9DUR
I posted a solution to this weeks ago. It works great. I've been in a hotel using this solution to do digital all week. I specifically did this to run it via WAN over a slow connection, but there is no reason this couldn't be used inside the LAN when DAX cannot be used.
https://community.flexradio.com/flexr...1
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 772 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 371 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
