Piority items for 1.5
Alan Nusso, N4BV
Piority items for 1.5: NR, NB, ANF, ATU MEMORIES, GUI PERSISTENCE, TRANSMIT DELAY SETTING PERSISTENCE IN "RADIO SETTINGS".
6
And RTTY/FSK mode. (Decode optional).
3 -
Fill Panadapter, Band Stacking Memories2
Free DV , S-meter correction for VHF with 20 dB , 2x hor. and vert. marker lines with read-out in the pan adaptor , squelch in all modes .3
If they fix the NB, I will do the happy dance! Everything else is icing on the cake for me. I wish I didn't live in such a noisy environment.
DAX IQ Sample rate persistence when changing profiles!2
A P F
https://community.flexradio.com/flexradio/topics/ssdr_v1_2_apf_could_use_more_gain_it_seems_diminish...
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com1 -
I'd really like to see SQUELCH for SSB and maybe even AM....4
Since CW, SSB, AM and Digi have lots of built-in one-click filter selections, its time for standard tone (high and low) RTTY filters to be built in, along with FSK.
I guess lucked out and have the right kind of noise, not that any noise is good, the noise blanker works great for me...
The noise blanker virtually wipes out my severe noise problem. A signal totally disappears on the spectrum display and can't be heard with the NB off...
Turn on the NB and I can copy the station just fine. It's better than any other radio I have tried, including the TS-590s & FTdx3000.
Ken - VE5KC
Pure signal and the ability to store recordings on your PC please...5
The noise blanker doesn't work well for me at all. The few times it does work, it doesn't lower the noise level in the panadapter. When I use my flex-5000 on 160 meters I have a S9+10 power line noise. When I turn on the NB, it cuts the noise down to about S7 and ALSO lowers the noise floor on the panadapter. The 6000 series doesn't lower the visual noise floor on the panadapter. You can't see any weak signals when the visual noise floor is high.
The noise blanker on my 5000 is wonderful. Best I have ever used on any radio. I just hope when 1.5 comes out it is as good as the 5000.
I would like band markers like PSDR had.
Jon...kf2e
7 -
The NB and NR in the 5000 were as good as from mine IC 7800. Waiting for 1.5 update to see what the omprovements will be.
I would like to see FREEDV, and RTTY decode other than that this radio and 1.4.3 and this Audio system now is killer. thanks FLEX keep on truckin
Jim
WU5E
5 -
Yes early versions had more gain and could pop weak signals out of the floor. That changed about 1.3.1
Would like to see the ATU optional on receive. Frequently monitor 4 bands of JT-65, when the ATU is engaged on one band the sensitivity of the other bands may suffer.2
I would like for the yellow line and TX width that marks the frequency on the Panadapter to go through into the waterfall.4
As part of the "buff and polish"
https://community.flexradio.com/flexradio/topics/idea_to_improve_the_swr_and_power_scale_readability
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com4 -
you were one step ahead of me in that request
Yup... I'm surprised at not having marked band edges etc... It's a "gotcha" while spectrum cruising. What about markers (like the band edges in PSDR) that can be placed where the user wishes ? That would be Great to mark band edges & also any other noteworthy locations. A labelling function would really make this feature useful...
Please don't forget to support the RTTY offset and bandwidth so we can click on a spot and radio will jump to the proper freq and BW for Fldigi or MMTTY or whatever decoder we're using....
Dennis, k0eoo2 -
As part of the "science experiment" to improve DSP and noise mitigation.
https://community.flexradio.com/flexradio/topics/option-to-automate-the-agc-t-setting
Regards, Al / NN4ZZ
Burt, every radio come equipped with a contest filter, the Flex is no exception. It is the big power switch on the front.. Guaranteed to filter all contesters if you push it right. hi..
On the positive side, though I am not a contester, I do enjoy making some contacts with stations that normally would not acknowledge my weak signal. During a contest they go to great efforts to copy me (I must be a multiplier or something like that). In the end after a bunch of giving my call and signal report several times, I am always rewarded with a 59... hi..
73.. Ken - VE5KC
How the NB looks like in other DDC/DUC rigs:
https://youtu.be/YP2m9T0pygc
i think we need to have at least better ....1 -
I don't know if filling in the panadaptor display (as in PSDR) would have an adverse effect on b/w? It makes for a much neater and more legible display. Also, at present I use TNF markers to display band edges, and even though I know I can't accidentally transmit out of band this was handled much better on PSDR. Minor details I know, but IF they are easy to implement they would tidy things up nicely.
ATU memory is important to me; having to retune every band change is a real nuisance (yeah, I know, get a better antenna!). I don't want to invest in an external ATU if this is planned for the next release, but one would make life easier in the meantime.
Jeff - G4IUA1 -
That's the way my Flex-5000A works with PSDR.
Hmnn... good idea in the meantime...using TNF's to mark band edges etc.
My main list...
1) The DSP "Science Project" on all DSP items - NB, NR, ANF, APF, TNF (although TNF is working superbly) If they get this right, WOW what a rig this will be!
2) ATU Memories - no more need to retune after changing band, mode, TX profile, ANT port, etc. This is my biggest time waster in a competitive situation.
3) Streamline and unify the Profiles, Memories, Band registers, etc. so that they all work seamlessly -- not having different characteristics for each method of entering a frequency.
4) Automated AGC-T settings, with adjustable "knee" point.
5) Dual-peak RTTY Filters, adjustable "sweet-spot" frequencies, for easy click & go RTTY operation.
6) Band / Sub-band markers - either pre-edited, or editable by the user.
7) GUI & Display improvements - many have been floated by NN4ZZ and others.
If even the first half of this list is in V.1.5 I would be very pleased, and could wait until 1.6 for the rest of it!
Ken - NM9P
3
- 341 Community Topics
- 611 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 406 SmartSDR for Mac
- 265 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 373 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 197 FLEX-8000 Signature Series
- 919 Maestro
- 889 Genius Products
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 746 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 965 Third-Party Software
