enhance remote with USB port with COM port converter from read panel !
I have been using the new remote functionality and it works great ! and I am preparing myself to the WAN remote, having a connection only to the FLEX IP device.
My actual architecture need to be modified
To have a full station control (using only the flex) usb ports are needed directly from flex itself;
Actually I use station master to do relays and PA switching and they need smartcat and DDUTIL sw on the local PC and flex is connected diretly via ethernet, but in remote I wont be able a local PC, as switching hub
So flex should be enhanced with standard device to control accessories, I think , I'd like !!
Hi Don,
Here are some previous posts about connecting peripherals directly to the radio.
https://community.flexradio.com/flexradio/topics/band_data-3xef1?topic-reply-list%5Bsettings%5D%5Bfi...
https://community.flexradio.com/flexradio/topics/looking_all_over_for_band_data
Guess it may be a while before we see it but it will be needed eventually for true WAN Remote and to meet the goal of "no local PC." At least it will be for many of us that use antenna switches, amplifiers and antenna rotators and want to control them also.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com1 -
tnx Al
I think we have different possible solutions:
1) a K3TUF like external box with relays
2) an new external box a usb/com port)
3) an enablement of USB port in flex which will need a smartsdr development
let see !
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
