How do I interface HDR with my new Flex 6300
John AD6NR
John AD6NR Member ✭✭
edited September 2018 in FLEX-6000 Signature Series
I now have my new Flex 6300 installed and working well with V1.4.0.53 - awesome!   I tried to set up and use HRD as my logger but I'm stuck!  I checked the HRD page but nothing I could use.  Can someone help?   I will also need to use N1MM+ in the future.  Thanks in advance.   John AD6NR
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    I am glad you asked that question. I contacted HRD tech support asking the same questions and their answers wanted to make rush to my nearest toilet.
    Jim, K6QE
  • K6OZY
    K6OZY Member ✭✭✭
    edited February 2017
    https://community.flexradio.com/flexradio/topics/smartsdr_ham_radio_deluxe_dm780_howto_setup_guide
    Follow that setup, but just skip the DM780 part and open HRD Logger after you have done up to step 4
  • John n0snx
    John n0snx Member
    edited April 2015
    The simplest way is to use DDUTIL to fun HRD... I use HRD for my logging and don't have any issues... a couple mouse clicks and its setup... easy as pie with DDUTIL
  • K6OZY
    K6OZY Member ✭✭✭
    I agree that DDUtil is the better way to do this now too.   Make sure to set the HRD Server to "v6.2".   I do this instead of using the main HRD app.
  • Rick Hadley - W0FG
    Rick Hadley - W0FG Member ✭✭
    edited January 2018
    Agreed.  Simply install DDUtil, enable HRD Apps, check v6.2 and then open HRD-Log.  Simple as pie. If you decide to use DM780 you will just need to add a PTT port in SDR-CAT.  I'm also using HRD Rotor control with the ERC board connected to my Yaesu G-800DXA.  You can click on a spot out of HRD Log;s DX Cluster and get hands-free antenna pointing too.
  • Jim Gilliam
    I am not clear on the technique. Is all of this accomplished on a REMOTE computer or is it done with a host computer therefore, perhaps, needing two computers. One by the radio and another as a client from which to operate remotely.
