How do I interface HDR with my new Flex 6300
John AD6NR
I now have my new Flex 6300 installed and working well with V1.4.0.53 - awesome! I tried to set up and use HRD as my logger but I'm stuck! I checked the HRD page but nothing I could use. Can someone help? I will also need to use N1MM+ in the future. Thanks in advance. John AD6NR
I am glad you asked that question. I contacted HRD tech support asking the same questions and their answers wanted to make rush to my nearest toilet.
Jim, K6QE
https://community.flexradio.com/flexradio/topics/smartsdr_ham_radio_deluxe_dm780_howto_setup_guide
Follow that setup, but just skip the DM780 part and open HRD Logger after you have done up to step 40 -
The simplest way is to use DDUTIL to fun HRD... I use HRD for my logging and don't have any issues... a couple mouse clicks and its setup... easy as pie with DDUTIL
I agree that DDUtil is the better way to do this now too. Make sure to set the HRD Server to "v6.2". I do this instead of using the main HRD app.0
Agreed. Simply install DDUtil, enable HRD Apps, check v6.2 and then open HRD-Log. Simple as pie. If you decide to use DM780 you will just need to add a PTT port in SDR-CAT. I'm also using HRD Rotor control with the ERC board connected to my Yaesu G-800DXA. You can click on a spot out of HRD Log;s DX Cluster and get hands-free antenna pointing too.0
I am not clear on the technique. Is all of this accomplished on a REMOTE computer or is it done with a host computer therefore, perhaps, needing two computers. One by the radio and another as a client from which to operate remotely.0
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 256 SmartSDR CAT
- 942 Maestro
- 785 Peripherals & Station Integration
