Flex 6000 Series and SmartSDR shut down
Bill / VA3QB
I have owned a Flex3k for about 2 years. I have done much to resolve the PowerSDR shutdowns due to RF.
My question is, if I upgrade to a 6000 series that uses a network cable instead of FireWire will it get rid of this problem.
Bill
Bill
Why do you think you have an RF problem? If you do, why don't you concentrate on good Amateur practices, instead of trying to solve it with a different radio?0
Bill,
I'm not sure who would hazard such a guess. But you could ask yourself one question, do any of the network cables in your shack have RF troubles?
I had a 5k and never had any RF issues. 6000 had no RF issues0
I think we are approaching the question haphazardly.
My first question would be to ask, "what issues did you have with the 3000 and how did you solve them?"
This would give us an idea regarding the nature of the problem and if the issue was addressed (removing the RFI from the shack) or was it mitigated by putting chokes on every cable.
So Bill - can you provide a little feedback to my question?
You're probably going to get a lot of answers on this one. First, yes, if your problem is the Firewire cable inducting RF into the system then you will fix it with a 6000-series upgrade. If, like me, you need a little nudge to break out the checkbook, then this is your nudge.
IEEE 1394 isn't the best way to move as much data as the Flex moves between the radio and the computer. It was the best available at the time the legacy radios were in production, but it's just about been abandoned by the industry in light of various other methods. Consider that another nudge.
My experience with RF is that the best place to start is at the source. Resonant antennas with low SWR. Grounding. Good transmission lines with well grounded shielding. Even then, you can still end up with RF. One of the most common areas for intrusion is through the mic cable. Heil shielded mic cable worked for me. Next is ferrite beads. Some say you can't have too many - I guess that's true if it fixes the problem.
Good luck with the search and destroy mission.
Is it stand-alone or connected to your alarm system? If it's stand-alone, give up ham radio?0
Let's not hijack Bills post. If you have a different issue, please start a new topic.0
Hi Tim
Sorry for the delay have been in transit on my return trip from Florida this winter combined with a nice bout with the Flu.
My problems stem from some RFI in the shack. I switched the Firewire cable to a "Granite Digital" and installed some (a lot) chokes on the Firewire as well as the network and USB cables. I have two 10 foot copper ground rods next to the tower and have a 6 gauge ground cable run into the shack as a ground as well as one run to the electrical box in another room.
All my radio equipment is grounded as well as my computer.
Even with all this I still get PowerSDR shut downs on occasion. Particularly on 40 and 80 mtrs. Then you have to power off the radio and restart the radio and program.
It is not always possible to remove all RFI from the shack, and I find the Flex 3000 with a Firewire very sensitive to RFI. It will shut done even as low as 25 watts .
I never had this problem with my old FT-1000MP running a serial cable to computer running HRD.
This is very annoying especially when in a QSO.
My original question is, RFI or not, does Smart SDR with a Flex 6300 or 6500 shut down due to RFI ?
Bill
VA3QB
Hi Bill,
I had a similar experience on my 6700 and documented the solutions on my web page:
http://www.nn4zz.com/FLEX6700.htm#RF_issues_and_solutions
http://www.nn4zz.com/FLEX6700.htm#Ethernet_Lightning_Protection
Your issue may be different but I don't have any more problems regardless of the band or power. Hope the links are helpful.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
Hi Al
In your grounding pictures you show the copper cable in a parallel loop. Where did you get the clips that connected the cable to the wall and the clips that connected to the cables for connection to the hardware. Also is there a reason for a parallel loop of copper ground wire.
Bill
VA3QB0 -
Hi Bill.
The clamps and wire were left over from my house lightning rod project. All of the parts and wire are from Harger.
http://www.harger.com/harger.html
Here is the page for the clamps. Wire, and other parts also available for complete lightning and grounding systems.
The clamps are designed for two conductors. Mechanically it better with two although it will clamp on just one wire. I had plenty of wire so the the parallel loop of wire worked well.
Harger used to sell direct on the web but now you have to go through one of their distributors.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com0
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
