Hercules MIDI with 6300
Ok after reinstalling. Start SmartSDR then start FlexMidi. Tune around in SmartSDR with the mouse. Verify the frequency is changing correctly in the FlexMidi App window. If the frequencies are not updating correctly let me know. If they do update correctly, you should be able to use the controller.
Keep me posted.
William
One other note, every time before using the Hercules, it is a good idea to verify they are synced by starting both VFO's and tuning them around with the mouse. Then verify the FlexMidi App is properly synced. Once they are synced everything should work properly. You only need to do this if you close the FlexMidi App. Closing SmartSDR makes no difference.
William
William,
I have found that occasionally, upon initial start-up of the program, that "VFO-B" does not get read by the software and turning the tuning knob makes it start tuning with whatever frequency happens to be in the cue...usually 0.000 Mhz. It then sends the Slice to that frequency. (I have occasionally found this on Slice-A after the slice has been closed and opened on a different band.
But if some other action happens on the controller, or on the rig with a mouse, that the program reads the Slice-B frequency and things work fine. Often I will simply hit the button to change TX to B then back to A and things work fine. I am not sure what a software solution to this might be. Perhaps it is doing the initial frequency read before the program is fully connected to the rig and is missing it?
I have a similar delay the first time I turn RIT or XIT ON. It misses the first button press, then everything works fine after that. Occasionally this is true on the mode switching as well. Ahh, the mysteries of software development.
I remember many years ago when programming that it was sometimes necessary to "toss a null" at a serial port to "clear the lines" or initialize it before using it. I don't know if any of that is valid any more.
Ken - NM9P0 -
No changes. Same as b4.
If i start FlexMidi he takes the QRG from SmartSDR correct. If i turn VFO button SmartSdr jump to 3.000.000 but FlexMidi using the old freq and counts up or down only at FlexMidi display. Flex it self is fixed.
Balance A-B also work wrong. At right side VFO A is at highest level; at left side quiet (if i only using 1 VFO)0 -
VFO speed is also wrong. Full CCW is fast, full CW is slow.0
Can I ask which version of FlexMidi you are running 32bit or 64bit? Also what version of SmartSDR.
Chris, just found an error in the code in the latest version. This may have been what caused your issues. Give me a few to test it and I'll post an update.
The balance works correct for me, middle both speakers on, slide it right only the right speaker, slide it left only the right. The balance for VFOB is backwards on purpose. This is done so you can listen to each vfo out a separate speaker
"VFO speed is also wrong. Full CCW is fast, full CW is slow." This is the way its supposed to work. Maybe I should of called it "Delay". Its meant to slow down the VFO's for fine tuning. You can change it is you like. The source is included.
As for the code I'm uploading a fix for the error I found. This only affected VFOB. Please give it a try and let me know.
Uninstall the previous version and just install this one manually. Just unzip the files and run the app under the application.windows32 or
application.windows64.
https://www.dropbox.com/s/re9tlop8r7y7wje/FlexMidiTCP.zip?dl=0
William, here W7 64
Will download try now lastest version, QRX
NO changes,
SS=SmartSDR FM=FlexMidi
start ss, vfo shows 3.505.00
start fm, fm vfo 3.505.000
change freq at ss to 3.515.000
fm shows also the new freq 3.515.000
now i using vfo button from fm
ss jump to 3.000.000
fm shows 3.515.000
i dial ff vfo down to 3.000.000
ss shows always 3.000.000
i dial ff under 3.000.000
ss jump to 2.000.000
Install manually, first at disk
and then also at C: - no difference
also no difference between W32 and W640 -
Chris, I tried the exact step you did, but everything worked as expected for me. What version of smartSDR are you running??
Are you running a English or German language for windows?
Something is causing the app to not send the correct frequency to smartSDR. This is whats causing the VFO to jump.
FlexMidi is receiving the correct frequency from smartSDR, as it is displaying it correctly in the APP. When you turn the VFO dial it should increment the frequency and send it back to the radio. This is where it breaks. It obviously is sending garbage, because your frequency jumps by 1mhz not 10hz like it is supposed to.
Something in your system is breaking the math, But I need to figure out what is different in your setup that may be causing this.
run SS1.4
but it's a good point ( it was also still idea here b4 ) i using the german version of win and between USA an DL there is a difference in using DOT and COMMA
It a nice place for doing "errors" - i remember the old CT contest software day's0 -
Chris in FlexMidi. Does the Frequency show a dot or a comma? I think we are getting somewhere.
FM 3,515000 COMMA
SS 3.515.000 DOT (2 times)0 -
Ah Ha, FM should be displaying a dot. So I need to rethink how to account for this. Give me some time to think about this. I'm sure this is whats causing the issue.
Let me try a few things and get back to you.
William
I have a file uploading for you to try. Lets cross fingers!
I'll post the link shortly
William
Chris, Extract and run this version. I suspect your computer is using commas instead of periods in the calculations. Then its sending the number with the comma back to the 6000. The 6000 does not know what to do with this. In this version I convert the frequency to text, than replace the comma back to a period before sending to the 6000. Let me know!
If this version does not fix it, I have another idea also.
https://www.dropbox.com/s/77j3vvsh5h7dgt5/application.windows64.zip?dl=00 -
Now it works!
Will test all other buttons/function.
Will give you feedback
73 Chris
DL5NAM0 -
Woo Hoo!!! Let me know what else you find. Glad I could help!
I will incorporate this modification in all future releases.
William0 -
Got the Midi controller today from Amazon... Very cool I must say. William you are a good man! I will continue to play, thanks0
Glad its working foe you!
I made a few updates. First I incorporated a fix for countries that use a commas instead of decimal. Also added a few more LED functions for PTT & STEP. Renamed VFO speed to "VFO delay" and reduced sensitivity. Updated the main graphic to represent current layout.
Regards,
William
W4WHL
I made one more update. Added VFO swap. Now you can swap A<>B which is useful for syncing logging software.
William,
Just got my Hercules DJ from B&H (www.BandH.com) for $119, installed the basic drivers and your latest version of your program. Up and running with my Flex 6300 in about 5 Minutes!
Thanks for your great program!. Now, to really work through your code and learn something new. Perhaps use a Raspberry PI to provide the network interface...
73 Javier
KC2QII0 -
Good deal! That's why I wrote it. I never intended to write a program for distribution. It just took off. Glad its working for you!
William
William,
I also loaded into my laptop as well, and it is running through my wireless without any problems.
Great Job!
Javier0 -
Hey, guys, I am doing some cleaning up and semi-final additions on my version for the DJControl MP3 LE. I have figured out how to: use a single button to toggle functions, Access the lights on the keys. Simplify some of the tuning and RIT/XIT codes, And other functions. I am a couple of days late, but I hope to post a link to my version tonight. If I get stalled, I won't be able to do anything for a while.... I have a wedding on Thursday, and next week is Holy Week, my busiest week of the year! So far, things are going well, if I don't program in my sleep... Then things get messed up quickly! Ken - NM9P0
looking forward to seeing your version, Maybe some of your ideas are better than mine, so I can steal them ( I mean borrow). Ken you may want to look at my latest and see how I solved the comma issue in case someone Germany wants to try your code.
WIlliam
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
