DSP visual indication request - final note
Barry Isseks
The more I look at the slice info, the more I am convinced that the DSP failure to remain lit (in the slice) when underlying functions are enabled is a "bug:" Look at the RIT/XIT as example.. it stays lit when the underlying functions are enabled.. (even with the additional indications in the Pan Adapter) This is expected behavior. So should the DSP light remain lit when any DSP function is enabled. Is this not logical. Ergo - my call out as a "bug".
Sounds like it Barry. The SSDR standard is 'lit blue means on/active'. The behaviour is anomalous as you say. Well spotted.
Blue indicates it is active unless it is grayed out an in that case it has been disabled due to a rule or condition that disables it. It become re-enabled (not grayed out) when the condition is no longer applicable.0
Thanks Tim... Hope to see this resolved in upcoming releases.0
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
