DSP visual indication request - final note
Barry Isseks
Barry Isseks Member ✭✭
edited December 2018 in SmartSDR for Windows
The more I look at the slice info, the more I am convinced that the DSP failure to remain lit (in the slice) when underlying functions are enabled is a "bug:" Look at the RIT/XIT as example.. it stays lit when the underlying functions are enabled.. (even with the additional indications in the Pan Adapter) This is expected behavior. So should the DSP light remain lit when any DSP function is enabled. Is this not logical. Ergo - my call out as a "bug".
  • DrTeeth
    DrTeeth Member ✭✭
    Sounds like it Barry. The SSDR standard is 'lit blue means on/active'. The behaviour is anomalous as you say. Well spotted.
    edited December 2016
    Blue indicates it is active unless it is grayed out an in that case it has been disabled due to a rule or condition that disables it.  It become re-enabled (not grayed out) when the condition is no longer applicable.
  • Barry Isseks
    edited July 2015
    Thanks Tim... Hope to see this resolved in upcoming releases.
