PC audio TX setting causes tempoarary distortion in Phones and Rear audio output
Keith Richards
Flex 6300 v1.4 with PC setting selected for audio TX
As soon as the 6300 has booted and green LED is solid I notice if I talk into the mic I get distorted audio "breakthrough" output from the rear connection and Phones outputs. I have external powered speakers connected and the output is fairly loud. This happens without SmartSDR starting and I'm not keying the radio.
The distorted mic sourced audio (harsh clipped "Darlek" like sound) gradually gets quieter and disappears after around 30 seconds !
I noticed this phenomenon not because I like shouting into the mike waiting for the boot-up but because the problem manifests itself in a more disruptive way when SmartSDR starts and clean resolved RX audio is fed through to the audio outputs and speakers - the mic picks up the RX audio and is output to the audio jack in a distorted form, mixing the two together.
I thought what was happening was that the AGC was set to "off" or "fast" and clipping was occurring - this is not the case. So the net result is badly distorted RX audio when the radio first starts. The problem gradually disappears after about 30 seconds from switch on.
As soon as I switch to ACC TX input and restart the radio this phenomenon disappears.
Regards
Keith
GW0HYU
Regards
Keith
GW0HYU
Is anyone else seeing the problem that Keith has described?0
I wonder if it is a strange connection or grounding problem?0
Hi Tim,
I'm trying many scenarios here to isolate this to confirm if its something local to my installation.
Doesn't seem to be a wider issue as surely somebody would notice the same - other than many would be remote to their radio for obvious reasons and wouldn't typically be listening to the local AF outputs. I just use the digital PC option to help circumvent RFI in the TX. I guess you can't recreate at your end ?
Do you think there is any rationale behind what I'm experiencing ? Bizarre how the distortion tails off and vanishes after 30 seconds - I'll try and capture on a video.
One thought - I use a RME Fireface UFX external DAC (Firewire interface) to convert Mic audio via class A mic preamp into the computer. The software is low latency ASIO driven and presents the computer with several audio ins and outs so I am able to choose between setting many devices (allbeit one at a time) as the default record or playback device which equates to a particular fader / channel. http://www.rme-audio.de/en/products/fireface_ufx.php
This is a pro level piece of kit and drivers are rock solid - used in many pro recording studios.
Anyway its no big deal for me as Ive switched back to the ACC input so I can also use the RCA PPT - digital PC option doesn't support that control option yet need to click MOX (hopefully will later though ?)
Best Regards
Keith
GW0HYU
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 772 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 371 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
