Audio Settings for SmartSDR 1.4 and Parallels Access?
N3HQB
N3HQB Member
edited February 2019 in SmartSDR for Windows
I'm running SmartSDR 1.4 on a MacBook Air using Windows 7 running in Parallels 10.  I'm using Parallels Access to remote video and audio in/out to an iPhone 6+.  Has anyone been able to work out the audio TX/RX settings for Flex LAN remote operation using Parallels Access?
  • George KF2T
    George KF2T Member ✭✭✭
    Set windows speaker and mic as defaults (Control Panel, Sound) then use default as devices in Parallels. Works like a champ.
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited January 2017
    BUT  Make sure that Access is connected to the PC when you do what George suggests
     Windows may fail to find the Parallels devices as defaults because they do not exist when Access is not connected..
    Also found that you may need to restart SSDR if the assignments of devices changes...
    Other than that it works like a champ
    Been switching between DAX Audio and Remote Audio for Parallels Access ... not sure which i favor yet...albeit Remote Audio is much easier to set up...
  • N3HQB
    N3HQB Member
    edited March 2015
    Thanks, working fine now (Forgot to select "PC" in the P/CW panel MIC dropdown.)
  • KY6LA_Howard
    edited January 2017
    The one issue of using PC is that you no longer have the use of the equalizer on transmit. Apparently this was by design
