Audio Settings for SmartSDR 1.4 and Parallels Access?
N3HQB
I'm running SmartSDR 1.4 on a MacBook Air using Windows 7 running in Parallels 10. I'm using Parallels Access to remote video and audio in/out to an iPhone 6+. Has anyone been able to work out the audio TX/RX settings for Flex LAN remote operation using Parallels Access?
Set windows speaker and mic as defaults (Control Panel, Sound) then use default as devices in Parallels. Works like a champ.0
BUT Make sure that Access is connected to the PC when you do what George suggests
Windows may fail to find the Parallels devices as defaults because they do not exist when Access is not connected..
Also found that you may need to restart SSDR if the assignments of devices changes...
Other than that it works like a champ
Been switching between DAX Audio and Remote Audio for Parallels Access ... not sure which i favor yet...albeit Remote Audio is much easier to set up...
Thanks, working fine now (Forgot to select "PC" in the P/CW panel MIC dropdown.)0
The one issue of using PC is that you no longer have the use of the equalizer on transmit. Apparently this was by design0
