PA Temp readings
James Whiteway
Somewhere I read a post by Steve that detailed the changes in Flexlib api that corrected the value returned from the api when reading the PA temp. Try as I might, I cannot find that post!
So, I'm hoping someone, (Steve maybe) has the correct method to read the meter with v1.4 of the api. Currently, using my testbed program, I get a reading of 5,180 degrees F ! Of course, that's using a workaround that was posted in the API section that corrected erroneous readings that the previous version of the api returned.
Any leads?
james
Any leads?
james
Hi James: The value returned to your method will now be in degrees C. No need for multiplier. I have not done much to my flex app but will definitely look at that wiki. 73, Tom K1FR1
Here is what I use - all I had to do was comment out the *64.0f multiplier:
private void radio_PATempDataReady(float data) {
Console.WriteLine(",,,,,,,,,,,PA Temp data event handler fired");
float PA_temp_data = data;
//PA_temp_data *= 64.0f;
PA_temp_data = (PA_temp_data * 9.0f / 5.0f) + 32.0f;
textPATemp.Text = String.Format("{0:f1}", PA_temp_data) + " F";
works like a champ! So nice to have folks here that are willing to help.
james
Just for your reference, here's what I wrote for temp James:
private void OnPaTempDataReady(float data) {
// Need a multiplier to correct the value on 1.3.8
if (data < 1)
data *= 64;
PaTempTextBox.Text = data.ToString("###0.00");
// At 70, fan goes to its highest setting according to Eric
if (data >= 70)
// The radio shuts down at 90! So give 10 degrees warning.
PaTempTextBox.ForeColor = data >= 80 ? Color.Red : Color.Yellow;
}1 -
Ohhhhhhhh, I like that! I'm assuming you're using Celsius instead of Fahrenheit for readout. So, I am thinking of making a selection where the user (me for now) can choose between degrees Celsius and degrees Fahrenheit. I think I can actually do that one !! hehehe
Thanks again for posting Peter. Definitely adding this to the test app and my code snippet collection.
james
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
