Hercules MIDI with 6300
Ken, the only file you need in that download is a file called FlexMidiTCP.pde. Just edit that file in Processing. You need to update this line in that file:
myBus = new MidiBus(this, "Hercules DJControl Instinct", "Hercules DJControl Instinct");
To get the correct name of your device, create a new sketch with just this:
import themidibus.*;
MidiBus myBus;
void setup() {
size(400, 400);
background(0);
MidiBus.list()
A list of all available MIDI devices will be printed.
After editing that line, try running the program from processing. Check if everything works. If not there is an example under the midibus library called basic. edit the same line:
Run this program a then just start turning knobs and hitting buttons. Write down each channel,note, value etc. Then just update my PDE with your values. The commands in the sketch are pretty self explanatory, so you should have no trouble figuring out what goes where.
After that adding new functions get a bit harder. You have to dig into the API to find them. I will help where I can.
W4WHL
My guess is the mappings are the same or very similar, I doubt you will have to change much. to get basic functionality. And once you get everything working to your liking, just export it to an aplication.
William, looks like they took your drop box link and my last question off the thread.
Please send me the link to N3VE at arrl dot net thanks, Jeff0 -
I switched browsers and it is there, please disregard last post
Jeff
For CWX memories, I don't think can be a accessed via another client, so in order to do it with MIDI controller, you will just have to program a button with a canned message. And also how to program a dial for wpm speed. Like this:
void controllerChange(int channel, int number, int value) {
//CW speed ?? = Pick a dial
//if ((channel == 0) && (number == ??) && (value < 101)) {c.write("C44|cwx wpm " + "+value+"
void noteOn(int channel, int pitch, int velocity) {
//CW Canned Messages ?? = Pick a button
if ((channel == 0) && (pitch == ??)) {c.write("C44|cwx send QRZ CQWW DE W4WHL K
if ((channel == 0) && (pitch == ??)) {c.write("C44|cwx send CQ CQ DE W4WHL K
Etc Etc.
Of course you will only want messages that NEVER change. If you want to get fancy, you could write a GUI to input and change memories, but this adds complexity. Its simpler for me to just update the code
Another option that would be much easier, is to create a XML file with all your memories, then have the program pull them from the XML file. I may work on this when I get time.
William
Nevermind you can send CWX memories no problem here ya go:
if ((channel == 0) && (pitch == ??)) {c.write("C44|cwx macro send 1
if ((channel == 0) && (pitch == ??)) {c.write("C44|cwx macro send 2
if ((channel == 0) && (pitch == ??)) {c.write("C44|cwx macro send 3
if ((channel == 0) && (pitch == ??)) {c.write("C44|cwx macro send 4
I will add this to my code this weekend
W4WHL0 -
Here is the newest layout, I will post a link later today or tomorrow once its tested.0
The balance does interesting thing, It switches A to left ear, B to right ear or vice verse. In the center it mixes both channels. So you can listen to slice a in the left ear and slice b in the right (or vice verse), centered you hear both in both ears, or any combination of the above. If only one slice is open its acts as a standard balance, but the balance is reversed for slice b. This was done on purpose.
That was quicker than I thought. all new functions work as in the above photo. I will post the new code in about 20 min.
W4WHL
William, what version of the Hercules are you picturing above?
Ok I made one more update. I added mode switching. Not sure how I forgot that
And here is the link to the new download. I complied 64 & 32 bit versions.
https://www.dropbox.com/s/re9tlop8r7y7wje/FlexMidiTCP.zip?dl=0
Danke schön!!!0
Den man gerade willkommen
Ken, Did you get a chance to try this?
W4WHL
I made another small update, the main screen now displays VFO frequencies. I thought it would be nice to have some visual feedback the program is doing something.
Here is the updated download;
Not yesterday, I ended up with too many projects. Perhaps today or tomorrow. I will be able to work on it.0
Looks really nice.0
Hi William.
I have downloaded Processing and made a sketch with your little routine to discover the midi name of my controller.
It stops with an error message
"unexpected token:null"
what's going wrong?0 -
MidiBus myBus;
void setup() {
size(400, 400);
background(0);
MidiBus.list();
Sorry This works
Thanks. Now it says:
"the package "themidibus" does not exist. You might be missing a library.
no library found for themidibus
Libraries must be installed in a folder named 'libraries' inside the 'sketchbook' folder."
I copied the 'lib' folder from the zipped file you sent me and put it into the folder that "Processing" set up for the new sketch I entered. Then I named it "Libraries" and it still gave me this error.
I'm learning, but have a long way to go. But I learn fast with the proper information. I will also look for a tutorial/guide online.
BTW, I didn't find your email on QRZ.com
Thanks for your patient help....0 -
in processing, you need to Sketch>Import>Add Library
Then search midibus and install
William
If you have google chat ping me at lee.hemmingsen@gmail.com its faster. I will be happy to help with these little things. Once the library is installed properly it should work.
SUCCESS! sort of...
I now have limited control using the Hercules DJControl MP3 LE MIDI Controller.
After loading the midibus library, the find midi device sketch worked.
Then I had to change the access name in your main program from
to
DJControl MP3 LE MIDI" and then it came to life.
Unfortunately some of the controls so nothing, and all of the controls that do anything are in the wrong place and the tuning dials are very slow. but this is a matter of tracing the correct midi note and replacing it on the controller.
Thanks.
Now, is there an easy way to move a control, knob or button and see a readout of what its code is so that I can direct it to the correct command?
We are getting places now!
Ken - NM9P1 -
Ken emailed you, but will post here also
To figure out what knobs and buttons are what, run this example code under the midibus library.
Under examples its Contributed Libraries>The MidiBus>Basic
Update this line as you did before: myBus = new MidiBus(this, -1, "Java Sound Synthesizer"); //
Then it should print out the numbers as you turn the nobs and hit the buttons.
Write down what channel/number(or pitch for buttons) is for each knob. Then just take that info and edit my code.
For example
This is for rit freq up
if ((channel == 0) && (number == Change this) && (value == 1)) {rit_freq=rit_freq+10; c.write("C44|slice set 0 rit_freq="+rit_freq+"
This is for rit freq down
if ((channel == 0) && (number == Change this) && (value == 127)) {rit_freq=rit_freq-10; c.write("C44|slice set 0 rit_freq="+rit_freq+"
If you need help locating a particular function let me know.
Once you get it going, I will help you speed you the dials to your liking. Also the windows software that comes with the Hercules has a utility to change the jog speed.
William
VFO speed select is more to slow it down vs speed it up, but who knows what your knob(whichever one it is) is set at. This is the line to edit wit the correct number to match you controller.
//VFO speed select
if ((channel == 0) && (number == Change This)) {speed = value; slowdown=0;}
I received my Instinct today and have it working. I must tell you it was a lot of fun figuring this out as I am not a programmer.
Jeff N3VE
Please keep posting updates as you complete them, thanks to you William.
By the way what is your call?
great!! How is it working for you?
W4WHL
Works quite well, now all I need is an Elmer to help with the PW-1 and ddutil
William, Thanks for all the effort and for sharing the files. For anyone who wants to go this route, below is an eBay link. Best Buy has them via the link for $129.95 with free shipping. http://www.ebay.com/itm/Hercules-DJ-Control-Instinct-2-Deck-DJ-Controller-Black-/191532833101?pt=LH_DefaultDomain_0&hash=item2c983f194d Dmr0
Let me know if you think some functions should be moved or replaced. I would like to maybe create a couple different layouts.
one thing to note. When using 2 slices, make sure the frequencies show up correctly in the MIDI software. If not just move the slices with the mouse once and everything should sync.
Also I would like comments on the VFO scroll speed. My "Speed" dial was to slow it down, not speed it up. So I could make fine adjustments. But wondering if its fast enough? It currently uses 10Hz stepping,
User defined layout may come one day, but that is 100x more coding. So for now a couple popular layout options would be easier.
William
W4WHL
- 342 Community Topics
- 612 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 407 SmartSDR for Mac
- 266 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 374 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 199 FLEX-8000 Signature Series
- 919 Maestro
- 890 Genius Products
- 452 Power Genius XL Amplifier
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 748 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 971 Third-Party Software
