SB-201 connection to 6300
David Parkinson
I have a sb-200 and have installed the Harbaugh mods including the soft key, do I just need to connect the PTT on the radio to Ant Relay and Alc to Alc and go? I've looked elswhere but it has all gone over my head. Thank you
David, check out pages 33 and 37 of the Series 6000 hardware manual this will probably answer any questions you have.
TX RELAY OUTPUTS [1,2,3] TX1, TX2 and TX3 (TX on FLEX-6300) are outputs for keying external equipment such as amplifiers, external T/R switches, etc. They are all individual outputs, isolated from each other. Refer to the SmartSDR documentation for explanation on how to configure the timing for each output. – The TX Relay outputs are designed to handle signaling levels of up to +40 VDC @ 140 mA maximum. Some older amplifiers exceed this voltage level and damage to the radio can occur if directly connected. Verify the voltage/current on your external device before connecting to TX Relay 1-3. If there is any doubt or the levels are too high, use a buffer/isolator box between the radio and the external device.
http://www.flexradio.com/downloads/flex-6000-hardware-reference-manual-pdf/
David Be safe and use a relay BUFFER between the radio and amp....The SB201 does not have an ALC so you will not use the ALC on the radio. With an amp that age I would use a relay buffer for sure.
David, if you have the softkey mod in the SB-201 you don't need a relay between the rig and amp. That's the whole purpose of the softkey mod. And don't bother with the ALC connection - you don't need it. Hook the TX output on the 6300 to the Ant Relay input on the Heathkit and make sure RCA TX1 is enabled in the radio setup under TX.
Doug K4DSP
Thank you so much guys,,,you have really helped me out...I really appreciate it.0
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 773 Maestro
- 42 FlexControl
- 728 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 373 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
