How to adjust window to fit screen
Tom
I have a 28 inch HD monitor and screen resolution is at max. I cannot get all of the SDR window to show. It is missing most of the small window bottom right corner with the AM Carrier controls. It has been this way since I got the Flex 6500 last year. How can this be fixed?
What operating system?
Minimix the window and then use your mouse to adjust the width and height.0
Check the resolution of your screen monitor and be sure it is set to it's maximum value. Just right click your mouse on a vacant part of your screen and click on screen resolution to check where it is set.0
My monitor, with a vertical resolution of 1080px (which is a pretty typical, it's a 1080p panel), isn't large enough to view all of the right side controls at once.
I usually just keep the EQ closed, which allows the others to fit just fine.0
- 113 SmartSDR+
- 920 Genius Products
