How to adjust window to fit screen
Tom
Tom Member
edited September 2018 in SmartSDR for Windows
I have a 28 inch HD monitor and screen resolution is at max.  I cannot get  all of the SDR window to show.  It is missing most of the small window bottom right corner with the AM Carrier controls.  It has been this way since I got the Flex 6500 last year.  How can this be fixed?
    edited March 2017
    What operating system?
  • Terry K8EET
    Terry K8EET Member ✭✭
    edited July 2016
    Minimix the window and then use your mouse to adjust the width and height.
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    Check the resolution of your screen monitor and be sure it is set to it's maximum value. Just right click your mouse on a vacant part of your screen and click on screen resolution to check where it is set.
  • Ben Sinclair
    Ben Sinclair Member
    edited March 2015
    My monitor, with a vertical resolution of 1080px (which is a pretty typical, it's a 1080p panel), isn't large enough to view all of the right side controls at once.
    I usually just keep the EQ closed, which allows the others to fit just fine.
