DDUTIL 3.0 and FLEX 1.4 not sure what is wrong
James Kennedy-WU5E
Member ✭✭✭
Temp of the radio is sky high now, how come , radio feel cool to the touch. but the Temp reads 1,937.0 C
Sounds like you need to update to latest version of DDUtil.0
Make sure to download and install the latest version.
http://k5fr.com/DDUtilV3wiki/index.php?title=Download
Version 3.1.0.17 http://k5fr.com/binary/DDUtil31017_Setup.zip
IMPORTANT Make sure to take screenshots of your current configuration before you install as the new DDUtil will wipe the settings.0 -
thanks working like a champ now
Jim
Glad you posted this! I have 3.09.**** and it kept telling me I had the latest ver, so I suspect the autoupdate has a bit of an issue (in the prev version). Several changes with the later version I notice that could be useful.0
You are lucky since stell melts at around 1,500 C. Could have been a real mess.2
Version 3.1.0.17 is not without it's own problems. It occasionally becomes disconnected and Mode becomes inop (greyed out) and the mode can not be changed. To fix this, go into settings and then save out of setting and that will reset the Mode button. As for disconnection, DDUtil must be shutdown and restarted. Everything else works fine.
Since it breaks your current installation it's best that the non-autoupdate happens the way it was planned to, it's not a bug, or an accident, but an intentional safety feature. So that you would have the option to read the release notes and ask questions, and decide when you had the free time to do the upgrade.
73, Jay - NO5J0
- 371 Community Topics
- 93 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 246 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 451 Remote Operation (SmartLink)
- 996 Third-Party Software
