V1.4 works fine
Takeshi Yamada
Takeshi Yamada Member ✭✭
edited April 2017 in SmartSDR for Windows
It works fine, but I noticed a minor bug.
   XIT/RIT  -1009X is displayed as -1009 (LSB omitted).
   Network Diagnostics window is different from what is in the user guide?
Sidetone with CW at REMOTE I commented before was my mistake.  It gives sidetone with CWX and it is the right behavior.
Thank you FRS for your big effort.
73 de JI1BNU
Ken Yamada
  • Tim - W4TME
    edited March 2017
    I suspect this is a DPI scaling issue as it displays correctly on my screen.  It is possible that there is a localization issue too.  Are using yous a Japanese language version of Windows?
  • Takeshi Yamada
    edited March 2017
    Yes, I am using Ja version of Win 9.1 on 4K display (3840 x 2160) .  Tried some display setup, changing text font size etc. did not help.
    Maybe it is because of the font it is using.   I pointed the same question before with v1.2.
    It is expanded to 5 digits and it may not be so confusing.
    Thank you Tim.
  • Sergey R5AU
    Sergey R5AU Member ✭✭
    edited April 2017
    Tim, i will check today later on my 5K with Win10 and report further here
  • Tim - W4TME
    edited December 2016
    It may be the fonts in the Ja version of Windows.  Can you take a screen shot of the RIT indicator @ -10090 so I can see how it is changed?
  • Tim - W4TME
    Thanks.
  • Sergey R5AU
    edited April 2015
    Everything OK displayed on my iMAC 5k with split over 10khz - > Takeshi, check you Video drivers or ability of OS to support 4K-5K
    iMAC 5K -> Parallels-> Win 10 Technical Preview
  • Takeshi Yamada
    edited March 2017
    Tim
       Here it is.
  • Tim - W4TME
    Thank you for the screen shot.
