SmartSDR v1.4.0 No Transmit Power Output on FM
K9DUR
Loaded SmartSDR v1.4.0 onto my FLEX-6700, s/n 1713-3011-6700-4673.
I decided to try out the new FM capability. I went to 29.600 MHz on 10m & also to 52.525 MHz on 6m. In both cases, the panadapter shows carrier when I key the rig & sidebands when I talk, but external power meter shows 0 Watts out.
73, Ray, K9DUR
Cold boot the radio by powering off and removing DC power for 15-30 seconds.
I cannot confirm this behavior. My FM puts out power and I can key a local 10M or 6M repeater. Perhaps backup your profiles, reset the radio to defaults, try again. Import profiles after testing to verify a profile isn't the cause if Tim's suggestion doesn't work?
PS. Your software is awesome. Thank you for contributing to the community.0 -
I had to toggle the RPT controls a couple of times to get things. Once it kicked in, it's been sweet.0
Okay, Tim,
I get 30 lashes with a wet noodle! Found out no power out in any mode. So, I was in the process of doing exactly that when I read your reply. I had meant to do a cold reboot of the radio after the install, but was so anxious to try out the new "stuff", that I forgot. All is well now. Thanks.
73, Ray, K9DUR
- 248 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 773 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 373 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
