Smart S-Meter Problem
Joseph Duerbusch
edited February 2019 in FLEX-6000 Signature Series
I am trying to use the Smart S-Meter with my Flex-6300.
It works fine by it self, it uses the CAT port 4.  But if I open up Writelog, I get a comport4 in use.  And Writelog cannot connect to Flex-Cat (same port).
Same way, if I start Writelog up, then CAT works fine for RigControl.  Then start Smart S-Meter, I get a 'CatPort busy!" error.  It seems to me if Smart S-meter was designed to use Flex-Cat, and Flex-Cat is only used for RigControl, then it should be designed to share the port?
What am I missing?
Joe K0BX
  • George KF2T
    George KF2T Member ✭✭✭
    You'll need to create a CAT port for each application you want running simultaneously. Best bet is to have a unique COM port for each application, period, so you never have a conflict. In the CAR menu, go to the Serial Ports tab, and "Add a Port" for each - make them "dedicated" unless they're for PTT only.
    Enjoy!
  • K2ERA
    K2ERA Member
    edited March 2015
    Is Smart S-Meter an add on software for the Flex 6000 series?  Could you provide a link? I am unable to find it.
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited January 2017
