Smart S-Meter Problem
Joseph Duerbusch
I am trying to use the Smart S-Meter with my Flex-6300.
It works fine by it self, it uses the CAT port 4. But if I open up Writelog, I get a comport4 in use. And Writelog cannot connect to Flex-Cat (same port).
Same way, if I start Writelog up, then CAT works fine for RigControl. Then start Smart S-Meter, I get a 'CatPort busy!" error. It seems to me if Smart S-meter was designed to use Flex-Cat, and Flex-Cat is only used for RigControl, then it should be designed to share the port?
What am I missing?
Joe K0BX
What am I missing?
Joe K0BX
You'll need to create a CAT port for each application you want running simultaneously. Best bet is to have a unique COM port for each application, period, so you never have a conflict. In the CAR menu, go to the Serial Ports tab, and "Add a Port" for each - make them "dedicated" unless they're for PTT only.
Enjoy!0 -
Is Smart S-Meter an add on software for the Flex 6000 series? Could you provide a link? I am unable to find it.0
- 402 Community Topics
- 693 The Flea Market
