Error Code: PSL-3V3-2.95 ??
K1FR
Just had that error code come up on the 6700's front panel. It was in small font just below the "Shutting Down" message that normally comes up when radio is being shutdown. Radio came back up with the Flex Radio logo and seemed to be unresponsive. A hard reset (held power button until radio turned off, followed by power removal for 10 seconds) now has everything appearing to be back to normal.
Just wondering what might have been the cause of the error? I was debugging some software I had written using the SmartSDR API when things went south. That code is working fine, may have been circumstantial.
Thanks.
73, Tom
K1FR
Thanks.
73, Tom
K1FR
I run a 6300, so no front panel errors for me. But, it might be that your app did not exit gracefully when shut down and caused the error. (not that I ever have done that! J/k) Maybe one of these days Flex's developers will have the time to enumerate their error codes for outside developers.
Hopefully, Steve will show up and give us the lowdown on that error.
james
Jame: Hello! Roger - probably a self inflicted bug. Today has been rotten, icy weather so have been inside having fun writing code. Still just a learning project. Now have things so I can display and track the frequency and mode for multiple slices. Turned out to be easy - I had really been making it hard for myself trying to look at the Radio.SliceLIst class. If you would like copy of the updated version, let me know and I will zip and email to you.
73, Tom
K1FR0 -
Glad things are getting better. It's been icy here too. So, I did a bit of coding too. Nothing great, but fun anyway. I'd be glad to see what you've done. Send whatever you wish. When I get back in town, I'll send you what I've been working on. Nothing fancy, Just basic stuff. james WD5GWY0
Just sent it. Did not use the Verizon account, so hope it works.0
This error message indicates that the voltage on the 3.3v rail is below specification.
I have changed this post to a problem topic and converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
Thanks, Tim. Have tried to reconstruct what I was doing at the time to see if I could get a repeat. So for, it is a one off. I am a novice at C# and likely did something the radio did not like. Glad Flex put the API out there though - great learning project for me and allows me to play on the computer and the radio at the same time! 73, Tom K1FR0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
