Global Profiles Save
Ian1
I have now saved many Profiles using several Antennas Bands & Slice's.
How can I save them to a Flash drive so I don't loose them?
Ian
Ian
Use the Import/Export function under Profiles and export them anywhere on your system. Thumb drive will work fine.
If you need them back just Import them.
Dan --- KC4GO
Thanks Dan
Must be the Jet Lag I completely forgot about that.
Ian
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
