Global Profiles Save
Ian1
Ian1 Member ✭✭
I have now saved many Profiles using several Antennas Bands & Slice's.
How can I save them to a Flash drive so I don't loose them?
Ian
  • Dan -- KC4GO
    Dan -- KC4GO Member ✭✭
    edited March 2018
    Use the Import/Export function under Profiles and export them anywhere on  your system. Thumb drive will work fine.
    If you need them back just Import them.
    Dan --- KC4GO
  • Ian1
    Ian1 Member ✭✭
    edited May 2020
    Thanks Dan
    Must be the Jet Lag I completely forgot about that.
    Ian
