Cat stopped working
W4WHL
I just received my 6300, but smartsdr cat will not load. I get a error stating "Cat stopped working" Here is the error from the event log. I checked and the virtual serial port service is running. Not sure what to check. I tried on another computer and it worked fine. Not sure what could be causing this on this computer. Any ideas?
Application: Cat.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Net.Sockets.SocketException
Stack:
at System.Net.Sockets.Socket.DoBind(System.Net.EndPoint, System.Net.SocketAddress)
at System.Net.Sockets.Socket.Bind(System.Net.EndPoint)
at AsyncSocketsV2.server..ctor(Int32)
at Cat.Main..ctor()
at Cat.Program.Main()
Stack:
at Cat.Main..ctor()
Perhaps something corrupted in your computer for some unexplained reason. Have you tried restoring your computer to an earlier date? Sometimes the restore function corrects the computer to its former state when it was working.0
You are right on but I would add that the radio and the computer are partners in the station. Many people neglect the care and feeding of the computer and it can have all kinds of issues, especially stuff running in the background upon startup. Getting rid of the junk weekly with a pcclean type program makes the computer twice as accessable. The same people who would never miss brushing their teeth regularly, run a collectively cruder up machine and have these type problems! Bill, KI4B2
I have preached over and over and over again on this net to make a hard drive image and it always falls on deaf ears with an ensuing argument. Even the restore is better than nothing but you are correct.
Jim, K6QE
I image daily and religiously.
Lets not talk about the (windows, natch) PCs with broken prefetch or corrupt icon caches. See a lot of this when I service PCs. Big performance hits.
My PCs are like greyhounds - lean and fast.1 -
Guy tell me, would this be happening if the computer is only a Flex box?. I mean some use the computer for everything then run SSDR as well.1
Back to the original topic. I fixed my issue, And here is what it was if anybody runs into this;
My PC had another virtual com port driver I used with power SDR. I removed this driver and reinstalled everything. Now I have my log program work fine with the 6300.
So my advice is as said above, look for drivers and services that might be conflicting and remove them. A clean slate is always best for sure.
W4WHL
3 -
I doubt it. I do not use any computer as exclusively for Flex. All sorts of other stuff is going on at the same time - only stuff that is needed.
I have never come across a situation where heavy multitasking itself makes a program crash.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
