How to operate CW keying only via CAT.
EA4AK
Hi all...It looks like there is no way to diretly do CW keying via CAT (6700 / PC with windows 8.1).
I have red the related conversations here...
... but I would still like to ask the community to see if someone found a straighforward way to do it... directly or by means of any other piece of software.
I use N1MM+, HDR and DXLAB.
Thanks in advance.
Santos, EA4AK
ea4ak.santos@gmail.com
Thanks in advance.
Santos, EA4AK
Santos,
I use N1MM+ and can key via this program on my 6500. I connect via com4 and have the COM5-15 ports as follows: ptt dtr/rts
I hope this helps
Don
Hi Santos, I tried that and found that using the ZLP cw keyer with HRD DM780 and the 6500 on cw is the best way to get clear cw tones and qsk. http://www.g4zlp.co.uk/ 73, Alex DH2ID0
In my case I use the CWX function of the 6500, reports of nice clean cw. I then log using DM780/logger. At present DM780 has a minor problem with Add Log Entry which is being addressed for update, but a little manual input within the dm780 logger and its fine, not fast but ok.
If things really get hot and heavy then I use CW skimmer decoder as I cannot copy 30 wpm, but the con of that is the expense of cw skimmer.
Be advised that if you do try CWX, any hot-keys you set up (F1-F12) at this time the text will be sent twice. Flex advises that is being addressed for the next update.
My goal is N1mm+ but so far its set up eludes me, even with the tons of help available.
73 - Chuck W9NWR
HI Chuck,
I believe the "sent twice" bug in CWX only applies if you are in "LIVE" mode. It works fine for me when live mode is off.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
Thanks Al,
I will tuck that in my hat band and try it out. So far 100% of my cw has been in live mode, but I certainly appreciate the note and will give it a go.
73 Chuck
Thanks to all. CWX works great. Now I wonder how to set up N1MM.
Don:
Could you please send me a bit more detailed description of how you have your COM5/15 ports configured?
I assume this is a port pair created as a new PTT port, right?
Then, ... How is your precise configuration of port 5 in you N1MM+??
I have done the same, tried several configuration alternatives, but with no success.
Thanks.0 -
Your right Al, macros work ok in SEND. Between that and Live will get it done until update. Tnx.
Don,
I echo Santos' request.
Tnx Chuck
Santos,
try it like described here: How to: Setup N1MM+ for keying the Flex 6X00 via CWX
VY73
Tom
DK1EY0 -
done Tom, thanks !
Santos, EA4AK0
- 650 The Flea Market
- 152 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
