60 Meters
F5K No CW on 60 Meters and antenna tuner does not work there either. When I transmit CW an error message comes up saying no CW on 60 meters though the ARRL website says it is permitted. When I hit ATU there is no output power so it does not pull in the match. When I hit tune there is no output power. All these functions work fine on every other band.
  • DH2ID
    DH2ID Member ✭✭✭
    edited March 2017
    Hi Bill, please look at your SmartSDR settings. Did it load the US country file?
    You can see this under regions - change.
  • Bill-N6RV
    Bill-N6RV Member
    edited April 2018
    I am using a Flex 5000A. I use Power SDR not Smart SDR. I checked but do not see any country selection.
  • DH2ID
    DH2ID Member ✭✭✭
    edited March 2017
    Sorry, Bill, didn't see the F5k.... I also own a F3k. Maybe reloading the database helps?
  • Tim - W4TME
    edited March 2017
    Bill - are you using the latest version of PowerSDR?
  • Bill-N6RV
    Bill-N6RV Member
    edited April 2018
    Apparently not. I am using 2.2.3.19042. Dudley says I need 2.7.2
  • Tim - W4TME
    edited December 2016
    Yes, you need to upgrade to the latest version of PowerSDR.
