60 Meters
Bill-N6RV
F5K No CW on 60 Meters and antenna tuner does not work there either. When I transmit CW an error message comes up saying no CW on 60 meters though the ARRL website says it is permitted. When I hit ATU there is no output power so it does not pull in the match. When I hit tune there is no output power. All these functions work fine on every other band.
Hi Bill, please look at your SmartSDR settings. Did it load the US country file?
You can see this under regions - change.0 -
I am using a Flex 5000A. I use Power SDR not Smart SDR. I checked but do not see any country selection.
Sorry, Bill, didn't see the F5k.... I also own a F3k. Maybe reloading the database helps?0
Bill - are you using the latest version of PowerSDR?0
Apparently not. I am using 2.2.3.19042. Dudley says I need 2.7.2
Yes, you need to upgrade to the latest version of PowerSDR.0
- 683 The Flea Market
- 968 Genius Products
- 355 Tuner Genius XL
