Flex 1500 no SSB or two tone test output
jason kitchens
I have a 1500 that doesn't output any power when tx in SSB or with the two tone test in powerSDR.
Is there a hardware factory reset that I can try?
I cannot find a reference to one in the owners manual.
yes, in setup/factory defaults, you may have changed some settings along the way, or you can load a previous back up also from setup /
If a database reset does not work, submit a support ticket via our HelpDesk (http://helpdesk.flexradio.com) so we can assign you a case number.
For details on how to submit a HelpDesk support ticket, please refer to the following URL: http://helpdesk.flexradio.com/hc/en-us/articles/202118688-How-to-Submit-a-Request-for-Technical-Supp...
Once the support ticket is submitted, a support engineer will be in contact so we can work on the issue. Make sure to include your radio's serial number.0
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
