Terrible Rumble / Wind sound on launch
Steve Parker
I power up the 6300, wait for green light to cycle until solid, launch software, and WOW.....sounds like a rumbling wind storm, the speakers about jump off the desk. This has now happened 4 times in the 1st week of owning this rig. I unplug the power cord for a couple minutes, then it starts up ok.
Steve....I have noticed the exact same thing on my 6300. It has only happened about 3 times in a year. I just turn power off then back on and everything is fine. Can't figure it out either. Bob. K9LWA0
I had the same issue with my 6300. I found that it seems to be related to RX equalization. By turning off RX equalization, it stopped the noise. I leave RX equalization off, and have not had a startup issue since.
Glenn N8GL
Glenn
I've seen that EQ issue with my 6500, turning it off stopped it too. I'm waiting for it to do it again so I can see if immediately re-enableing matters.
Jay - NO5J0 -
me too, with my 6300... Just happened once.
Glenn's fix is the same one that worked for me. If you leave RX EQ on when you turn the rig off and then turn it on it produces that annoying sound. Just make sure to turn RX eq off. This is definitely a bug. Has anyone reported it yet?0
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 772 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 372 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
