Loading profiles
Bob G W1GLV
I've got a 6500 running under Win 7 and all of a sudden it will not load Profiles properly. When I select "Import", I select a file from the ones I've saved. Then I select "Import", it use to say Importing once selected but now it doesn't. It seems the Imported file is not completely imported since some of the saved parameters are no longer there. I've reset the radio and reinstalled SmartSDR v1.30. Nothing seems to fix this problem.
Many times some little things goes awry. Try restoring your computer to an earlier date when you made your last Windows update and see if your computer will behave.
Jim, K6QE
Jim, I did that. Doesn't seem to help.0
Maybe you didn't go back far enough. I am just guessing but I have had similar problems and going back far enough usually solved the problem.
Jim
Okay. Just seems if it has worked before (so I am assuming) something has changed.
Jim
- 379 Community Topics
- 631 The Flea Market
- 121 SmartSDR+
- 193 DAX
- 39 Aurora
- 947 Maestro
- 924 Genius Products
