Loading profiles
Bob G   W1GLV
Bob G W1GLV Member ✭✭
I've got a 6500 running under Win 7 and all of a sudden it will not load Profiles properly. When I select "Import", I select a file from the ones I've saved. Then I select "Import", it use to say Importing once selected but now it doesn't. It seems the Imported file is not completely imported since some of the saved parameters are no longer there. I've reset the radio and reinstalled SmartSDR v1.30. Nothing seems to fix this problem.
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited September 2018
    Many times some little things goes awry. Try restoring your computer to an earlier date  when you made your last Windows update and see if your computer will behave.
    Jim, K6QE
  • Bob G   W1GLV
    Jim, I did that. Doesn't seem to help.
  • Jim Gilliam
    Maybe you didn't go back far enough. I am just guessing but I have had similar problems and going back far enough usually solved the problem.
    Jim
  • Jim Gilliam
    Okay. Just seems if it has worked before (so I am assuming) something has changed.
    Jim
