DRM function of the flex.
I believe VAC2 is not implemented on the 1500 but that's all I know and cannot help on the DRM
has any one got dr to work on the 15000
Yes! I have DRM working on the Flex-1500. Works just fine -- when you can find a DRM station. (I understand that DRM has lost its lustre). Radio New Zealand is usually around.
To get it working I merely pipe my I&Q out to the VAC and use Dream. Takes a bit of futzing around with the settings in Dream, but I have found the 48 kHz direct I&Q to work best of all. Nice diagnostic graphs showing the decoding of the PAM modulation codes.
73 de Dave, N7AIG
ur using one sound card?
and rec only?
i have dream but been trying to use windrm0 -
Not sure I understand the question. No sound card at all. The Flex-1500 *is* the soundcard.
I never heard of windrm, but I just looked it up. "Hotest HF mode around..." ?? That web page was written 10 years ago in 2005. Is anyone using this mode today?
73 de Dave, N7AIG
i get u r useing the sound card in the computerif u output sound vac
ur not xmiting drm mode the windrm is to alow u to xmit and rec windrm narows the band with down to about 2.5 kc is best to use asecond sound card convert analog voice to dig i have not got it to work yet0 -
Wow, looks like an old joke script from Samuel Clemens.
Um, let's see, I am sending DRM audio out my computer audio port, so yes, I must be using the computer's audio "card". (it's actually a Dell laptop)
But I have never used WinDRM, and frankly never even knew DRM was being used on HF Ham bands. All I have ever done is pick up R. New Zealand, and a few others using Dream. Didn't hold my interest for much longer...
Sounds like you are having troubles piping your mic audio back into the Flex-1500? WinDRM would have to generate I&Q, I presume, and ship back through a second VAC pipe. My bet is that WinDRM might not be generating I&Q at the proper IF, if at all.
- de N7AIG
tnx reply it on the back buner 4 now
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
