Saving Recorded Audio ?
Lee - N2LEE
Lee - N2LEE Member ✭✭
edited August 2018 in SmartSDR for Windows
I know ssdr does not allow you to save recorded audio to a file but there must be a way to use DAX to redirect the playback to another app.
I was able to figure out how to record audio using DAX to an external app by redirecting DAX Audio RX 1 but how do you redirect audio playback to another recording app ?
I tried changing Audacity input to DAX TX audio but that is listed as reserved and does not work.
Any tips would be appreciated.
Lee
  • SteveM
    SteveM Member
    edited January 2017
    Nevermind my comment. Apparently, I misread your post. Sorry!
  • Jim Hawkins / K2JHV
    edited January 2015
    I have Audacity set as follows:
    Windows WASAPI
    And the input to "DAX RESERVED AUDIO RX 1 (DAX RX Audio) (loopback)
    Output on my machine is set to: "Speakers (Realtek High Definition Audio)"  (for playback)
    It works.
  • Lee - N2LEE
    edited February 2017
    Jim, can you clarify a few things for me ?
    1. When you playback audio recorded with SmartSDR you can capture it with Audacity ?
    I have DAX set to Channel 1
    Audacity input set to DAX Audio RX 1
    This will let me record directly via Audacity BUT when I playback audio that I RECORDED via SSDR it does not show up in Audacity.
    edited December 2015
    I just tried recording the playback on SSDR on Audacity and it worked.
    Set the Audacity output to "DAX Audio TX 1 (DAX TX Audio)" and you can play it back through SSDR provided the DAX button is depressed and the DAX control panel has TX on.  I just tried it and it worked.
    It looks like I would have to fiddle with levels because the recording is very low in volume when I tried it.  In other words, In order to playback at the same level you received it, you have to make some adjustments.  It's a bit awkward.  I had to shrink the SSDR screen "up" and Squeeze the Audacity window under it so I could control everything.
    Hope that helps.  --Jim - K2JHV
    PS:  The file recording and playback that was on my Flex-3000 was so convenient and that's an important feature FlexRadio should put back into the 6000 series.
