Saving Recorded Audio ?
Lee - N2LEE
I know ssdr does not allow you to save recorded audio to a file but there must be a way to use DAX to redirect the playback to another app.
I was able to figure out how to record audio using DAX to an external app by redirecting DAX Audio RX 1 but how do you redirect audio playback to another recording app ?
I tried changing Audacity input to DAX TX audio but that is listed as reserved and does not work.
Any tips would be appreciated.
Lee
Lee
Nevermind my comment. Apparently, I misread your post. Sorry!
I have Audacity set as follows:
Windows WASAPI
And the input to "DAX RESERVED AUDIO RX 1 (DAX RX Audio) (loopback)
Output on my machine is set to: "Speakers (Realtek High Definition Audio)" (for playback)
It works.0 -
Jim, can you clarify a few things for me ?
1. When you playback audio recorded with SmartSDR you can capture it with Audacity ?
I have DAX set to Channel 1
Audacity input set to DAX Audio RX 1
This will let me record directly via Audacity BUT when I playback audio that I RECORDED via SSDR it does not show up in Audacity.
I just tried recording the playback on SSDR on Audacity and it worked.
Set the Audacity output to "DAX Audio TX 1 (DAX TX Audio)" and you can play it back through SSDR provided the DAX button is depressed and the DAX control panel has TX on. I just tried it and it worked.
It looks like I would have to fiddle with levels because the recording is very low in volume when I tried it. In other words, In order to playback at the same level you received it, you have to make some adjustments. It's a bit awkward. I had to shrink the SSDR screen "up" and Squeeze the Audacity window under it so I could control everything.
Hope that helps. --Jim - K2JHV
PS: The file recording and playback that was on my Flex-3000 was so convenient and that's an important feature FlexRadio should put back into the 6000 series.
- 384 Community Topics
- 644 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
