Has anyone, found the Waveform API?
WA6FXT Mike
WA6FXT Mike Member ✭✭
edited February 2017 in SmartSDR API
I'm looking for the Waveform API. I found, downloaded, built and tested the SmartSDR API (FlexLib.dll); now, I'm looking to do some Waveform API testing and have not been able to locate the Waveform API.
Also, can someone tell me/us what SW toolset is used for the Waveform API? ARM, DeVinci, TI DSP and where to get it?
Thanks!
73's de Mike
  • Eric-KE5DTO
    Mike,
    Some information is available on the FlexRadio ADP page here: http://www.flexradio.com/amateur-products/flex-6000-signature-series/smartsdr-api/.  This will lead you to the public github repo for the waveform example.
    We are still working towards releasing the environment for developing an application to run inside the radio.  For the time being, you can develop similar code to run on the PC or a different platform (we have one example running on a Beagle **** Black, for example).  Let us know if you have further questions.
