An Interesting Audio Idea?
K6NOK- Bill
I have been thinking about adding a good quality communications speaker to my 6300. It seems though that most of the best reviewed speakers of that type are not amplified, and so I would need an audio amplifier to use with it. During my research I came across this little 25 watt audio amp by Pyle which could fit the bill. The interesting thing, to me. about it is that it includes the ability to broadcast the audio via bluetooth. That opens some interesting possibilities like bluetooth headphones and bluetooth speakers. Hmmmmmm....
http://www.amazon.com/dp/B00MIYET9E/ref=dra_a_rv_mr_hn_it_P1250_1000?tag=dradisplay-20&ascsubtag...
Wonder how it would live along side RF . Some just wont work .0
A metal case is essential !0
I have a couple Blue tooth devices I have been playing with and they both work fine at least using it on 40, 80, and 20 meters which I have used them on.
It would be nice if FLEX would enable the USB jack on the radio for a few of the different BLUE Tooth dongles to allow a direct blue tooth connection to Headsets, Speakers and serial devices.
Rig Blaster BLUE works VERY well with a BlueParrot head set and I am sure with Blue tooth speakers and has the RS-232 outputs just make sure you have the latest configuration down load.
Hiel also has a Bluetooth MIC adapter that plugs into the Balanced MIC jack and the other end to the XLR jack on a Microphone, Pyle make a bunch of devices that are designed for the RF environment so Blue tooth does work in a RF environment if you have your near field RF managed from my experience and tests at least.
I would say give it a try it may surprise you
73's
Bret WX7Y
One can set the PC up for BT: control panel -> sound
I use BT to listen to SW while in the observatory.
A Phiaton BT4.0 device works well and seems RF proof.
_..--
Tim
Most of the RF issues with speakers come from the speaker wire being resonant sending RF into the amp or into the speakers. It can also get in through the lead feeding the amp. If the speaker wire is picking up RF, a metal case on the amp isn't going to do much good.
I use Bose Companion II amplified speakers for one audio section. I also feed the audio into a Pyle amp, which drives two Bose bookshelf speakers. I use that in tandem when I really want to fill the room with audio. The Bose speakers are probably overkill but they do sound good - they do as good a job of replicating the noise as they do the signal.
Now, if I read the Amazon description right, the amp is capable of pairing with a phone or tablet to play audio. I don't see an input except for the auxiliary input on the front, so it looks like that's the intention. Also, I would be worried about the antenna on the back of it being an RF magnet.
I saw Bob demo this Bt adapter, It was interesting and it worked very well. Look mom no wires....0
XYL and kids gave me a BT headset for Xmas, the $70 Logitech cheapies. They work flawlessly. My shack is in the basement about 25' from the 43' vertical antenna (barefoot). I can wander about anywhere in the house with them. I can't use VOX, though, because my little ones are so noisy.0
These actually work great......no RF issues, and have 2 lines.....I run the rig and pc http://www.behringer.com/EN/Products/MS40.aspx0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
