Clicking on DAX Control Panel in SDR Bridge Brings Up Empty Box
I have been getting used to the powerful combination of SDR Bridge 1.0.0, CW Skimmer 1.8.3, WriteLog and the SSDR 1.2.1. Some of it seems a bit unstable but it's easy to see the power in all this once any issues are flushed out.
One problem I have consistently is when in SDR Bridge in the Bridge Tab and I click on DAX Control Panel, I get a popup box titled DAX Control Panel v1.0.5.49, but the box is completely black and cannot be closed once opened. This only happens when I launch the DAX control panel through Bridge. Launching the DAX Control Panel through the notification area works OK.
I am running a 6700 w/SSDR 1.2.1; Windows 8.1 x64. Here is what I get every time.
Please let me know if you need any additional info. Thanks again for making all this possible - I am truly having a blast.
- Bob, W1RE
Okay, I just re-read the Bridge instructions and I now understand better what is going on.
The instructions say you need to need to "initialize DAX Control Panel" or SkimSrv panel from the tray first due to the way Windows works. While I did do this, I didn't realize that you shouldn't close the DAX Control Panel before trying to re-launch from Bridge.
Basically you need to open DAX control panel from the tray first and leave it open then clicking the button in the Bridge effectively minimizes and restores the control panel in a toggle manner.
Given this it's not really a bug but a bit of an odd behavior. Once you understand how it's supposed to work it works well - I clearly didn't understand it the first (half dozen) time(s) I tried it.
Hope this helps others understand better how this works.
- Bob, W1RE
Bob, have you been able to use CW Skimmer on Windows 8.1? Mine only decode bit and pieces of the CW. Don ai6re0
Hi Don,
Yes I am successfully using CW Skimmer with Windows 8.1. Have you checked whether you are not CPU constrained as that would be my first guess. Maybe if you can provide some additional details of your set up it may trigger additional ideas?
73 + Happy 2015,
- Bob
Bob, I am running a 4th generation I7 that shows about 20% load and is just coasting. CWSkimmer runs but it fails to decode unless I do something to keep the focus on the program. If I click on any other program like SSDR on XMLog then CWSkimmer starts loosing data. I have tried with SDR Bridge and the same thing happens there. I run a much slower windows 7 machine and everything works great there. CW Skimmer is the only program on the system that does not work on Windows 8.1. I have re-installed and still no difference. The fact that you have it working no matter what the current window means that I must do some more research. It I open a sub menu on Skimmer then it decode everything great but as soon as I touch anything else on the desktop skimmer starts missing letters. My system is running with plenty of extra cpu and 16 GB of memory. This is off topic so can you reply to me at my QRZ email address. Don AI6RE0
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 774 Maestro
- 42 FlexControl
- 730 Genius Products
- 253 Tuner Genius XL
- 85 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 374 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
