Flex+5000 low power
Doug Allen
Maximum 50 watts out
Make sure the RF Drive level is set to 100. 50 is the default setting.0
Tim, Was that an original setting when I first set up the Flex 5000 using the wizard? If so, how do I get back to the wizard? If it's just the Drive setting on the left side of Power SDR- well, the power output tracks accurately from 5 watts to 50 watts and shows no increase beyond the 50 setting.0
Doug - I recommend submitting a support ticket via our HelpDesk (http://helpdesk.flexradio.com) so we can assign you a case number. For details on how to submit a HelpDesk support ticket, please refer to the following URL: http://helpdesk.flexradio.com/hc/en-us/articles/202118688-How-to-Submit-a-Request-for-Technical-Supp... Once the support ticket is submitted, a support engineer will be in contact so we can work on the issue. Make sure to include your radio's serial number.0
I have just purchased a Flex 5000a (my very first SDR transceiver) and have installed the latest version of KE9NS' PowerSDR software (2.8.0.83). My antenna is an end-fed dipole 40m-6m at 30 ft. My microphone is a Heil PR781G and it is connected via an adapter AD-1-Y8 to the front of my 5000a. I have followed all the setup instructions per PowerSDR. The ATU tunes the antenna down to 1.1:1 as expected. I have set the Drive in PowerSDR to 100 and yet the Fwd Pwr meter reading at peaks reads only 45-50 watts. I then connected it to an MFJ-267 dummy load and it shows 100 watts out on all bands. Why does PowerSDR not show the correct output on its meeting reading?0
It is reading correctly, the radio does not like the load from the antenna.
It may be RF related. What is the SWR before tuning or tuner in by-pass?0 -
It's not a peak reading power meter. It shows average power in SSB mode(s).0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
