Problem with initial 6300 update...
Dave
After unboxing my 6300 and clicking on the transceiver on the left side of the screen, it tells me I need to update. Soi click on update and everything goes fine until the very end. The green progress bar is all green and it still shows "update" and appears to be hung. Does respond to power switch or smartsdr. Any ideas anyone?
Start with a reset...Then download a fresh install and try again. Is the 6300 directly connected to your router?0
David - there are some troubleshooting suggestions in the Release Notes. Occasionally the radio will not reboot completely from a firware upgrade.
Pull the power from the radio, reconnect the power cable and then power it back on (this is known as a "cold"boot).
If that does not resolve the issue, then submit a support ticket via our HelpDesk (http://helpdesk.flexradio.com) so we can assign you a case number. For details on how to submit a HelpDesk support ticket, please refer to the following URL: http://helpdesk.flexradio.com/hc/en-us/articles/202118688-How-to-Submit-a-Request-for-Technical-Supp... Once the support ticket is submitted, a support engineer will be in contact so we can work on the issue.0 -
Thanks guys, a cold boot solved the problem... Whew! Had me concerned!2
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 769 Maestro
- 42 FlexControl
- 728 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 811 Third-Party Software
