HOW CAN I SWITCH MY AMPLIFIER WITH PTT LINE?
Manfred HB9FLU
TODAY I BOUGHT A NEW 6300 AND IT WORKS FINE. BUT I CAN'T SWITCH MY AMPLIFIER - IT WORKS ONLY WITH ITS OWN HF-VOX. WHERE CAN I CHANGE THIS SETTINGS?
Have you enabled the TX RCA jack in Settings?0
Please see the SmartSDR Software Users Guide, Page 81 for detailed information on how to enable the rear panel PTT jacks.
http://www.flexradio.com/downloads/smartsdr-software-users-guide-pdf/
Also make sure your phono keyline is connected to the TX connector the yellow one nearest the powerpole connectors and not in the ptt connector near the usb and ethernet sockets. Cheers Paul0
Yes all correct
I have the 6300 and it has no yellow connector0
aplogise there are 2 pairs of phono sockets red and white. its the white one labelled TX near the power pole sockets that you connect your amplifier to. cheers Paul0
Hi Paul,
per the Quick Start Guide for the Flex series of radios the white phono connector labeled TX (near the power pole connector) is correct for keying your amp relay.
regards, Larry K1UO
Thank you for your help. Problem is solved. 73 de HB9FLU0
What was it?0
Correct Larry, It was Manfred that had the problem, I see he has solved it now, I wonder what he did? Cheers Paul0
Ah yes... reading too fast :-).... Probably your good advice did the trick Paul.
Merry Christmas.
I used the wrong socket:-)0
Yep ...Merry Christmas to you and yours also. Cheers Paul0
I did exactly the same when i first got my 6300. Have fun and Merry Christmas..0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
