Windows 8 and SmartSDR losing connection
James Kennedy-WU5E
Member ✭✭✭
SmartSDR will lose connection to the radio under Windows 8 if the SmartSDR is not minimized. Anyone see this condition?
I think you mean "is minimized," right? No problem here (Windows 8.1).0
I have had the same experience on Windows 8.1 with SSDR lost connection while it is not minimized but not the currently focused window. I think Windows 8.1 treats tasks differently as CW Skimmer no longer functions on Windows 8.1. It fail to get serviced by the system in time to function correctly.0
So to maintain radio connection you must minimize Ssdr? If that's the case how do you even know if it's running? 8.1 here. Works great.0
8.1 runs fine here as well. No apparent problems even when running MacLoggerDX or DXLabs suite simultaneously.0
My SSDR works fine on 8.1 as long as I am checking the window from time to time. If I leave it running and the window is open in the background it will suddenly get disconnected after something more than 30 minutes. I usually click on the SSDR window more often than 30 minutes so most of the time it is not a problem. If it does lose the connection re selecting the radio and it will restart.0
You could probably solve this by disabling ALL power management so that Windows always runs. Your HDD is probably spinning down after a period of inactivity.
Jon...kf2e
Good idea Jon. It just occurred to me that I use a separate monitor for SSDR and never need to minimize.0
Jim,
You may want to turn this into a Help Desk question..
Make sure your Windows is up todate
Check that the Startup tab in the Radio Setup menu, says, "GPU Capability: Maxumum Graphics Acceleration" if not change your graphics settings, to prove this minimize the waterfall, SmatSDR is very graphic intensive .
Set you Power Options to "High Performance"
Laptops are usually pretty graphic/performance challeneged verses a desktop.
THANKS MY Windows 7 Desktop will be back tomorrow. Now I know I need a more powerful laptop.
Jim
WU5E
Windows 8.1 with no such issue.
Look elsewhere for the problem I have ran the 6300, 6500 @ 6700.
Good luck Ian0 -
This disconnect happens to me in a random pattern and I'm running Windows 7 with all current updates, system disk is an SSD, and no power saving enables in Win7 except for turning off monitor after 5 min's of inactivity. About half the time it disconnects, need to power cycle the 6500. Hopefully this is fixed in V1.41
SSDR says "GPU Capability: Maxumum Graphics Acceleration" when used with my laptop's integrated graphics card and runs maxed out without issue. It's an Intel 3000 HD which I do not think is known for its 3D grunt, hi hi.
Merry Christmas and Happy New Year.
I have the exact same random disconnects with Win 7, an SSD disk and power management turned off here as well Rob. Usually no other external activity except leaving it and other Ham programs left open and running.0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
