My Flex-6500 displays an error when booting up. SHUTTING DOWN... ERROR PSH1V5-2.66
W6NEK
Suddenly upon powering turning on my Flex-6500 this morning the transceiver fails the boot sequence and displays the error following error message" SHUTTING DOWN... ERROR PSH1V5-2.66. At this point the Flex blinks a RED LED 3 times with a short delay then repeats the RED LED flashing sequence. 1 have checked power, network connection, etc. Can anyone give me a hint as to where to translate this code so I have an idea what to fix or have fixed?
Many thanks for your input,
Frank - W6NEK
Frank - W6NEK
I believe the error message is complaining about an internal power regulator voltage that is dead or out of spec.. I fyou have not alreardy done so remove DC from the radio for a couple of minutes and try again.. If it still fails, open a support ticket with the flex help desk.
AL, K0VM0 -
There is a similar posting here, not identical error number but could not see if they had a fix!
http://tinyurl.com/n9sf6un
Its on this forum but the long link did not show so converted it to a short one...
And as Al said above looks like a support ticket jobby..
The three flashing red LEDs indicate that the firmware is crashing. I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.0
When I turn off all power to the Flex from my Power supply I believe that is the message I see along with a Red Power light till all power is removed.
Ian
Ian - As indicated above, if you are having a similar issue, please submit a HelpDesk support ticket. Opening a HelpDesk support ticket will ensure our highest level of customer service we can provide. For details on how to submit a HelpDesk support ticket, please refer to the following URL: http://helpdesk.flexradio.com/hc/en-us/articles/202118688-How-to-Submit-a-Request-for-Technical-Supp...0
- 375 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
