Profiles
Sergey R5AU
I have created plenty of profiles for easy to use my F6700, but i have a several problems with profiles in general (may be it some how crossing with persistence memory) :
1. After start RIG and SSDR in case at beginning i will select any profile and after will change the band via menu in the left side - "Radio connection lost". In case after starting SSDR i will use firstly bands buttons from the left menu and after that profiles - everything OK
2.Today i have critical issue and my RIG stop responding(again after playing with Profile and Bands buttons) even after cold restart, i did full reset with Power+OK button combination and afterwards on fact i recognized following cases:
a. Initially(on version 1.2) i exported my all profiles (with selection "ALL") - i have 6 profiles with CW, 6 with SSB and 6 with DIGI, after full reset of the my RIG i tried to import, but no success - import results: only 3 profiles with CW
b. In case of the creating new profile ex.: CW 10m, and you have different preferences ex. for 10m in CWX and TX also, call Proflle manager, then Save TX profile as "CW 10m", then Save Global profile as "CW 10m" and as result CWX messages under setup menu will not be stored or stored incorrectly(even as result you can have diferent CW message in CWX in different bands). In case change of the CWX message, you will use "Save Global" option only , you CW string will be stored for all profiles
Some body else have the same behavior ?
SSDR version 1.3.8, Windows 8.1
Sergey,
I have experienced the same problem you describe in Point 1.
I have NOT experienced the problem in Point 2 though I have not worked with new profiles in several days.
Mike N1MD0 -
You right Mike, i have no experienced before with symptom #2, but get it after full reset only.0
I have entered both of these issues as a problem report into our bug tracker for additional investigation. Thank you for the defect report.0
Thank you Tim!0
I have similar problems. When switching between profiles the 6500 seems to return to the last band that was in use. I created AM profiles for 10M and 75M. If the radio was on 20M, and I load either of the profiles, most of the settings are loaded but the radio goes back to 20M. The changeover is very sluggish, and behaves like the software is about to crash. Not very stable.
- 384 Community Topics
- 642 The Flea Market
- 148 SmartSDR+
- 436 SmartSDR for Mac
- 262 SmartSDR CAT
- 284 FLEX-8000 Signature Series
- 961 Maestro
- 935 Genius Products
- 343 Tuner Genius XL
- 799 Peripherals & Station Integration
- 142 Amateur Radio Interests
