read 2nd slice frequency to 2nd instance of WSJT-X
Don WB3FTQ
is there a way to send the frequency of Slice B to a 2nd instance of WSJT-X? running Flex 6500
Not positive, but probably not. Although you can set a second instance with another COM and DAX configuration, I don't think WSJT-X supports the command to read VFO B.0
I believe George is correct. I run multiple instances of WSJT .. One instance per panadapter/ slice per band With the 6700 I typically monitor 4-5 bands at once0
now that i think more about it i don't think there is any way to get the frequency of Slice 'n' (other than Slice A) out to a COM pair. Thanks for your input George, 73
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
