6700 killer on 160m!
Let me offer this. This past weekend I had tremendous success with diversity pulling out numerous weak signal situations both on 160 and 80 CW.
Using a series of Beverage antennas on RXA and either Inverted L (160) or 1/4 wave vertical (80)
No preamps. It was a killer combination. Repeatedly able to pick out ultra weak signals.
Future plans include a horizontal loop for close in work, but anxious to see how it works as second antenna for diversity.
Fun Fun Fun
Phil K3TUF
I believe I saw a comment on this message board from someone who uses two Pixel loops with their planes oriented perpendicular to each other. Do you think that any nulls at 45 degrees would be noticeable compared to being able to rotate the loop? From a distance (I don't own a loop), it seems that being able to switch between two fixed loops would be more convenient than using single loop with a rotor.
No clue and to be honest, didn't think about that. I had all the parts except the YUN and relay shield on hand so less expensive than a second PixelLoop.
Stu K6TU0 -
Well, no worries. One could always put up four Pixel loops and not be concerned about nulls in any direction. But then again, if those cards are on the table, how about two shared apex loop arrays separated by 360 meters? That should be adequate for our spatial diversity requirements. Yet again, if we are going to put forth that amount of effort, why not go for something really outrageous?: http://vk6ysf.com/Radio_Extremes.htm0
- 371 Community Topics
- 93 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 246 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 451 Remote Operation (SmartLink)
- 996 Third-Party Software
